Steel frame column-beam connection
1 REPLY 1
Jummybear
382 Views, 1 Reply
Is it possible to calculate in Robot such connection in steel design - connections? I didnt much that and robot offers to calculate such joint as a "tube truss node". If its not possible, can you add it to wishlist? Elemnts are made from hollow tubes.
1 REPLY 1
This is currently not possible as discussed here http://forums.autodesk.com/t5/Robot-Structural-Analysis/Hollow-Sections-Column-Beam-Connections/td-p...
The request has already been added to the wish list.
Artur Kosakowski
