Steel Designe Section check
9 REPLIES 9
Message 1 of 10
726 Views, 9 Replies
Hi!
I check section in Steel Designe according to EN 1993-1-1! And I have a question about results.
Robot gives the highest ratio of stress verificaton. In code there is note who says, that this verification can be conservative and it should only be performed where the interaction of on te basis of resistance N,Rd; M,Rd; V,Rd cannot be performed.
Can you comment this?
Than you!
9 REPLIES 9
Message 2 of 10
Rafal.Gaweda
File please.
Rafal Gaweda
Message 3 of 10
in reply to: Rafal.Gaweda
Message 4 of 10
Rafal.Gaweda
I see this :
Rafal Gaweda
Message 5 of 10
Yes, I know this. If tick elastic analysis, Robot start check this stresses.
But how much it is correct? If section check was made with N,Rd; M,Rd; V,Rd. EN 1993-1-1 6.2.1 (5)
Same situation: http://forums.autodesk.com/t5/robot-structural-analysis/strange-results-in-steel-member-check/m-p/59...
Message 6 of 10
Rafal.Gaweda
0.71 vs 0.48
Rafal Gaweda
Message 7 of 10
Sorry, I don't understand what do You mean!
Message 8 of 10
Rafal.Gaweda
Ration with \ without elastic checkbox ticked.
Truly saying I do not understand your question:
"But how much it is correct?"
Rafal Gaweda
Message 9 of 10
I'am sorry.
I mean - how you (Robot team) understand this NOTE from EN 1993-1-1?
Message 10 of 10
Artur.Kosakowski
When you force the use of elastic analysis RSA recognizes a sections as being of class 3. In such situation it is assumed that plasticity is not allowed and the design is done for the elastic state. If so, RSA uses formulas (6.1) from chapter 6.2.1.(5) for the interaction of normal and transversal stresses.
Both simple and compound scenarios are verified:
Section strength check:
N,Ed/Nc,Rd + My,Ed/My,c,Rd + Mz,Ed/Mz,c,Rd = 0.25 < 1.00   (6.2.1(7))  - normal stress
sqrt(Sig,x,Ed^2 + 3*Tau,y,Ed^2)/(fy/gM0) = 0.16 < 1.00   (6.2.1.(5)) -  - normal and transversal stress
Vy,Ed/Vy,c,Rd = 0.01 < 1.00   (6.2.6.(1)) - transversal stress
Vz,Ed/Vz,c,Rd = 0.00 < 1.00   (6.2.6.(1)) - transversal stress
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
