Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 18
827 Views, 17 Replies
Steel Design
...I'm trying to design the attached steel structure ("Steel\Aluminum Design") but robot 2015 crashes at 75%. Than the "Send Report" message pops out. What could be the problem?
Regards!
17 REPLIES 17
Message 2 of 18
Hi
I Was see your file and I try to analysis and steel design for all Combination
That is complete caculation and Result: all section not OK
Please see image below
BEST & REGARDS
Message 3 of 18
StefanoPasquini6790
Hi, try to open your model in repair mode, run the analysis and make the code check for bars.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 4 of 18
in reply to: StefanoPasquini6790
Hi Stefano,...
... just tried to open it in repair mode and run new calculation, but nothing happend,....it still stucks at 75%,....
Message 5 of 18
Rafal.Gaweda
Got it.
Checking.
Rafal Gaweda
Message 6 of 18
Ok, I've solved your Issue...
the problem was on the "Podroznica" code check rule. You have also many model Issue:
1) In modal Analysis you have converted 2 times the same loads, erase one of the wrong conversion;
2) You have assigned the modal masses to "MODAL XYZ", I suggest you to convert in dynamic masses;
3) There are many bars wrong modelled, I've modified it;
4) There are a cantilever bars, you have to create a specific rule for code checking for this.
Attached my modified model, in ARSA 2015.
Greetings
PasProStudio
Message 7 of 18
Problem with internal bracings in Bar Type definitiion for bars 110 and 111. In fact there are no internal bracings on these bars. Correct it or remove bars 110 and 111 from design list
Rafal Gaweda
Message 8 of 18
in reply to: Rafal.Gaweda
Thank you Stefano and Rafal,....it works!
Regards!
Message 9 of 18
Hi, guys.  The attached model seems to behave in a similar fashion.  Tried all suggestions, but the steel design does not even start...  We have tried various things, using the same protocol we used in the previous versions, but have not been able to determine what is it that we are doing wrong in this version.
Just in case it is important: I have simultaneous installations of ARSA 2013, 2014 and 2015.  Could it be related? Would it be better if I uninstall the previous versions (I don't really need them)?
Thanks.
Message 10 of 18
Rafal.Gaweda
Unselect this on ALL tabs:
Rafal Gaweda
Message 11 of 18
StefanoPasquini6790
Hi Pio,
the problem is in the definition of buckling parameters....I tried to check your structure removing the automatic definition of bucjling length and everything it work.
I THINK THAT IN 2015 THERE IS A BIG BUG FOR THE AUTO BUCKLING LENGTH DEFINITION. In 2014 and previous version this Issue it never happend.
If in a model you have defined the auto buckling length definition, and the bar do not have a transverse bar on its length, ARSA 2015 crash...and you have to correct the code check definition.
I hope that Adsk correct soon this issue.
greetings
PasProStudio
Message 12 of 18
Thanks, Rafal.
This works, and the process now starts.  It does not finish, though.  I took out the tension-only members that I defined in the model, and everything works smoothly.  So the question is now: how do we handle the tensión only members? I am sure this did not happen with the 360-05 steel design code.
Thanks!
Message 13 of 18
Grazie, Stefano.
What you mention is the reason why we did not catch it... we did it all the time in the previous version.  I appreciate your interest.  As soon as I removed all automatic buckling length determinations, the design worked.  However, we ran into trouble with the tension only members... It crashes as soon as it get to one...  I am curious as to why it it not happen in your design run...
Message 14 of 18
Rafal.Gaweda
Have you modified Tensor bar type in the way to remove automatic recognition of intermediate points for lateral buckling ?
Rafal Gaweda
Message 15 of 18
Hi, Rafal.
Yes... At least I think I did... here's a screen shot:
Pio
Message 16 of 18
Rafal.Gaweda
Rafal Gaweda
Message 17 of 18
Oh, ok.  Thank you.
Message 18 of 18
Corrected in Robot 2015 SP2
Artur Kosakowski
