Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Steel design
4 REPLIES 4
pevelor
1403 Views, 4 Replies
Steel design
Hi
I have modelled a full building with a lot steel columns.
The columns are not totally fixed in reality so I want to calculate them as pinned-pinned to obtain a safe result.
However, changing the releases on the columns gives me a ton of warrings because there is to many degrees of freedom.
I am wondering if there is another way of doing this or do I have to model the column again in 2D frame and change the releases there?
4 REPLIES 4
Artur.Kosakowski
in reply to: pevelor
Try to use partial releases instead.
Artur Kosakowski
@Artur.Kosakowski, Why does the input box for the partial stiffness coefficient turn red if the value is above 1?
Romanich
in reply to: Lauren.Schuster
Hi @Lauren.Schuster
1 - fully fixed
0 - fully released
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Hi @Lauren.Schuster
Following the explanation posted by @Romanich (thank you) I'm adding the link to the corresponding part of Help:
Robot Structural Analysis 2019 Help: Elastic release
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
