I have a problem as far as steel design is concerned when there are brackets in the constraction. When I do the steel design in Greek, the program crashes. When I do the steel design in English there is no such problem, however when I change the language in Greek and try to get the printout, the program crashes as well. Therefore there is no way for me to get the printout in Greek for steel design when there are brackets.
I have also filed a case (05882298) and the final outcome of that was:
"You can easly workaround it by changing a printout language in tools\preferences onto English in example. Unfortunately it changes all greek texts to english.
Yes it is close to such problem cause it regards to Greek language setting.
Program wanted to display a message after the calculations but it is a problem with finding a Greek version of such text."
Is this problem going to be fixed? Please let me know.
Hi
That's strange what happens on your computer. Both issues you reported now on forum were corrected in ARSA 2012.
Please respond to e-mail concerning greek outputs.
