Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Steel Design - (no) Buckling Analysis with offsets on beams
2 REPLIES 2
marko.glavinic89
377 Views, 2 Replies
I try to run a buckling analysis for beams with assigned offset, but i can't get the results. Seems like it wasn't calculated at all, while the lateral torsional buckling analysis is done correctly. What is the problem?
2 REPLIES 2
Do you mean steel design? Tension with bending rather than compression?
Artur Kosakowski
Indeed, i had so small compression force so it just got anullated by setting the offset on the beams. Now, i ran the calculations over again for the other beam and everything seems correct.
Thank you!
