Discussion Groups
Robot Structural Analysis
Member
zameerajmal
STEEL DESIGN - INSTABLE SECTION - SLENDERNESS - Beam design under ULS
729 Views, 5 Replies
06-18-2012 02:47 AM
I have generated 3D frame using RSA 2013 professional. When i verify the rafter beams under ultimate limit state, the results shown are instable. And when optimized under ULTIMATE it provides very large dimension beams. whereas when i used SERVICEABILITY METHOD, it is fine.
Please help me, how to verify beams in 3D generator.
Please find attached 3D design file
Kind regards,
Ajmal
Please use plain text.
Member
zameerajmal
Re: 3D Frame Generator- Beam design under ULS
06-18-2012 02:49 AM in reply to: zameerajmal
I ain't able to attach rsa file, please help me
find result snaps for reference
why can't i design beam under ULS
Product Support
Artur.Kosakowski
06-18-2012 03:06 AM in reply to: zameerajmal
ULS and SLS check are two different verifications,. As far as I can see the problem you have got is the exceeded slenderness limit. Looking at the buckling Z part you can see that unrestrained buckling length for 140 section is over 14m which way  too long weak the axes if this section. Have you set the buckling parameters correctly?
Artur Kosakowski
Member
zameerajmal
Re: STEEL DESIGN - INSTABLE SECTION - SLENDERNESS - Beam design under ULS
06-18-2012 03:14 AM in reply to: zameerajmal
I haven't set the paramters. I am a learner, student. how to set, will you please help me
Ajmal
Member
zameerajmal
06-18-2012 03:16 AM in reply to: Artur.Kosakowski
The beam length is 7.11 m
bay width is 14 m
Product Support
Artur.Kosakowski
06-18-2012 03:20 AM in reply to: zameerajmal
Assuming it is a 2 span beam then either you set buckling Z (and LTB) coefficients as 0.5L or you should define an intermediate restrain at this point and then set these coefficients as 1.0L  for each of the spans.
Artur Kosakowski
