Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
STEEL DESIGN ASD 1989 SLENDER SECTION
4 REPLIES 4
mgaafar
866 Views, 4 Replies
         I noticed on the steel design check using ASD 1989 9th edition that the calculated allowable stress is very low. I did a quick calculations and the allowable stresses should be way higher than the calculated values.
The section is a T-section with b=20mm , hw=140mm, tw=6.4mm and tf=6.4mm
I think RSA calculated Q wrongly as per file attached..please check.
and if that is a bug, how to overwrite this value to properly design the rest of the members?
4 REPLIES 4
Artur.Kosakowski
in reply to: mgaafar
Could you attach your hand calculations too please?
Artur Kosakowski
mgaafar
in reply to: Artur.Kosakowski
here you are...basically I think Q is calculated wrong, it can not be 0.02.
Artur.Kosakowski
Have you tried to use the latest version of ASD?
Artur Kosakowski
mgaafar
I am checking a Rig that was designed for API 4F, so I have to check it against the ASD 1989 9th edition, so it will be great if you fix that bug.
I will manually check the ASD code check in the 13th edition and will let you know.
Thanks.
