Discussion Groups
Robot Structural Analysis
Valued Contributor
mgaafar
STEEL DESIGN ASD 1989 SLENDER SECTION
453 Views, 4 Replies
02-13-2013 08:32 AM
         I noticed on the steel design check using ASD 1989 9th edition that the calculated allowable stress is very low. I did a quick calculations and the allowable stresses should be way higher than the calculated values.
The section is a T-section with b=20mm , hw=140mm, tw=6.4mm and tf=6.4mm
I think RSA calculated Q wrongly as per file attached..please check.
and if that is a bug, how to overwrite this value to properly design the rest of the members?
Please use plain text.
Product Support
Artur.Kosakowski
Re: STEEL DESIGN ASD 1989 SLENDER SECTION
02-13-2013 11:47 PM in reply to: mgaafar
Could you attach your hand calculations too please?
Artur Kosakowski
Valued Contributor
mgaafar
02-15-2013 09:30 AM in reply to: Artur.Kosakowski
here you are...basically I think Q is calculated wrong, it can not be 0.02.
Product Support
Artur.Kosakowski
02-18-2013 03:06 AM in reply to: mgaafar
Have you tried to use the latest version of ASD?
Artur Kosakowski
Valued Contributor
mgaafar
02-19-2013 09:31 AM in reply to: Artur.Kosakowski
I am checking a Rig that was designed for API 4F, so I have to check it against the ASD 1989 9th edition, so it will be great if you fix that bug.
I will manually check the ASD code check in the 13th edition and will let you know.
Thanks.
