I noticed on the steel design check using ASD 1989 9th edition that the calculated allowable stress is very low. I did a quick calculations and the allowable stresses should be way higher than the calculated values.
The section is a T-section with b=20mm , hw=140mm, tw=6.4mm and tf=6.4mm
I think RSA calculated Q wrongly as per file attached..please check.
and if that is a bug, how to overwrite this value to properly design the rest of the members?
Solved by Artur.Kosakowski. Go to Solution.
here you are...basically I think Q is calculated wrong, it can not be 0.02.
Have you tried to use the latest version of ASD?
I am checking a Rig that was designed for API 4F, so I have to check it against the ASD 1989 9th edition, so it will be great if you fix that bug.
I will manually check the ASD code check in the 13th edition and will let you know.
Thanks.
