Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
steel connection
3 REPLIES 3
306 Views, 3 Replies
steel connection
I'm new in Robot, and want to know if it's possible to design connector by myself - in Robot or in ASD then import into Robot - (not costumize one of the software connections), then analyze/check it in Robot?
3 REPLIES 3
Artur.Kosakowski
in reply to: 9491024
In Robot you can only verify the predefined connection types as available from the list in the Steel Connection module.
Artur Kosakowski
in reply to: Artur.Kosakowski
Thanks for your answer. What about designing a new connector in ASD (=Autodesk....Detailing) then export it to Robot for checking/analyzing.
Artur.Kosakowski
You cannot export connections from ASD to Robot. Such operation is not supported (available).
Artur Kosakowski
