Hi Rafael,
I am busy learning to design steel connections in Robot but have a structure (See attached), which has been designed with a number of members all intersecting at a single node.
I previously designed the connections with a seperate Excel Spreadsheet and as an excersise would like to redo the designs in RSA.
When i try to design the connections it gives me the error:
"Incorrect selection or geometry of connections"
Could you assit with the connection design of the frame? Or explain the error.
Or if i apply offsets to each member will RSA pick up that the geometry has changed?
Steve
