Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Steel Column Design
1 REPLY 1
veronica.revilla
499 Views, 1 Reply
Steel Column Design
I am trying to check the steel design for the columns for lateral buckling but it says that member is not a column as per image below. I have tried changing the member to column by code parameters. But still, the result is the same. I needed to check the lateral buckling, since the member is taken as a beam, its not calculating the lateral buckling.
1 REPLY 1
The LTB verification has not been done because either the section (profile) type is of the kind such check is not described in the design code (e.g. angle) or simply there is no bending (My = 0 ).
Artur Kosakowski
