In AISC 341-05 chapter 6.1 there is a limit for Fy = 50 ksi. This limit ensures that steel members must use Fy <= 50 ksi. The key here is that 50ksi is OK. The steel check in Robot checks to see if Fy < 50ksi instead of Fy <= 50ksi. See attached pictures. I get failing sizes due to this bug. Otherwise they would be fine. Simply change the check to make sure that the Fy value is 50ksi or less.
Would it be possible for you to make a screen capture from the corresponding page of the code please? Thank you.
Please download and install SP2 for Robot 2013.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
