Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Steel calculations. Code group design optimization by weight
3 REPLIES 3
aruser
341 Views, 3 Replies
I get a message saying "Calculations have not been performed for members (1) due to lack of some section parameters" when try to optimize by weight.
I am doing this with a user section database, I mean, with sections that I created manually in the section definition module.
I have checked the properties of each section. The weight is correctly in every section.
¿To which properties is refering the message?
Regards
3 REPLIES 3
Artur.Kosakowski
in reply to: aruser
Are you able to run verification for these sections when assigned to bars of a model?
Artur Kosakowski
aruser
in reply to: Artur.Kosakowski
Yes
Artur.Kosakowski
in reply to: aruser
Could you attach your user section database and tell which section to use for a sample bar as well as which should be selected as available for code group design please?
Artur Kosakowski
