Dear all,
Could you please help me to neglect the axial force in calculation of steel beam because of small value:
Thank you very much
Solved by dimogrec. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
I'm sorry
On the other hand I will size the opportunity to indicate the difference between these two solutions. In the upper one you control up to which value of axial force it can be ignored whereas for the lower one it is always ignored.
