After half days work Robot crashed without requesting for save. The file was opened as a new project and not manually saved.
what is the default file location for the newly created files? I cannot find the backup file now. It is set to automatically save every 10min.
where can I find the backup file.
Quick response would be good. Thank you
Solved by Pawel.Pulak. Go to Solution.
The automatic backup file RTB is saved in the same folder as the original RTD file.
But to make this automatic system start to work it is necessary to manually save the RTD file of the project at least once.
If you have not saved it at all then ...
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
