Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Stability problem [Industrial Hal in steel]
4 REPLIES 4
karimkamil16
306 Views, 4 Replies
Hello everybody,
After 48h trying to solve my structural problem, I choose to ask here how to manage that. My version of Robot is 2014 student one.
I have a ground surface of 55 X 90 (m), the height is around 12 m and the final objectiv is to get the most economics structure.
Here are my 2 problems  :
* After moddeling my structure with 2 frames, every calculation loads works but if I add a third one the matrix is not converging. I don't really know how to deal with that.
* My second problem is to know what kind of profil is usually used to create trusses ( Corners for bars but for members i tried UPN but it becomes quite high).
I attached 2 files , the V1 is the structure with 2 frames and the V2 is 3 frames one.
http://we.tl/6oVQvUPWhv
Thank a lot for the future answers.
4 REPLIES 4
IL_uke
in reply to: karimkamil16
I don't know if it was your decission, but trusses aren't connected with other ones. You can see it near the intersection 6/2(3) axis - shouldn't be there connection within trusses (on top of trusses)?
karimkamil16
in reply to: IL_uke
@ IL_uke
Thank you for answer,
I don't really see what you are talking about, do you mean the columns which are stopped at the second floor ? If it's that yes I assumed that it useless to reach the top. And Especially because those coloumns diseaper at the third frame.
Best Regards,
IL_uke
Try to change the analysis type for third case (VENT) as "auxiliary case".
In first post I mean the intersection of perpendicular trusses for example in node 238. Element 4551 is higher than node 238. Is it correct?
karimkamil16
in reply to: IL_uke
Ho you right, it's like that on the whole structure.
Thank you very much for your time, can I ask you what kind of profil would you use on trusses ?
