Discussion Groups
Robot Structural Analysis
StuartRogers
Spring / Damper within ROBOT model
433 Views, 3 Replies
08-08-2012 03:08 AM
I am looking into modelling a truss structure on brackets. Between the brackets and the truss structure there are elastomeric bearings.
Is it possible to model these bearings within ROBOT for a spectral analysis? Can I represent them with an element and specify their stiffness and damping?
Thank you for your help.
Stuart
Please use plain text.
Product Support
Artur.Kosakowski
Re: Spring / Damper within ROBOT model
08-09-2012 06:51 AM in reply to: StuartRogers
No as the modal analysis calculates undamped vibrations only. This would be possible for THA analysis only.
Artur Kosakowski
New Member
smedina62
06-20-2013 10:13 PM in reply to: Artur.Kosakowski
How I can model a damper (buckling restrained braced frame) on RSA?
Product Support
Artur.Kosakowski
06-20-2013 11:59 PM in reply to: smedina62
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Tuned-Mass-Damper-TMD-creation-with-RSA/m-p/...
Artur Kosakowski
