How can we use the Spreadsheet calculator with RSA 2013 ?
When I open it, there's no library !
Does anybody know how to use it ?
sorry but design content for Robot Extensions - Spreadsheet Calculator 2013 will be available in Subscription Center in about one month.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Best regards,
Dear Pawel,
Have we a date for Spreadsheet calculator 2013 ?
Best regards,
It has just been released and should be available for download from the subscription site either today or tomorrow.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
I can't run Robot Extensions - Spreadsheet Calculator 2013 on windows 7.
After lunching VBA window appears and that's all, look at the attachement please
Any ideas what's going on?
If you have Excel 2010 64-bit then this platform is not supported. You have to use 32-bit version instead.
It's a pity there is no popup window during installation process informing about such important information.
So how to use it in the coorporation company where whole software configuration must be the same 😞
I hope that you will be able to ask them to install you 32-bit office instead of the 64-bit one if you give the good reason for it.
Hi, I checked the version and it is a 32 bits version.
have you already encountered this kind of problem ? I just open a new building concept, then directly clic on add ons (I am translating a french menu into English, not sure this is the exact name) and select "spreadsheet calculator". Then excel 2010 32 bits version opens, but there is no popup screen with options allowing me to choose if it is concrete or wood materials. This is what I used to have before uninstalling/reinstalling on a new pc.
Help would be much appreciated on this. Thanks !
screenshot attached.
