in the name of GOD .
hello.
I use Robot Structural Analysis 2014 and I see a problem in this version.
the "Robot Extension-Spreadsheet Calculator 2014" doesn't support "Excel 2013" unfortunately.
it's a big problem for Robot 2014 because the version of this product is 2014 and version of Excel is 2013.
This is a very big problem for Autodesk is that the 2014 version of your product, but with a 2013 version of software of another company isn't compatible.
Unfortunately Spreadsheet Calculator does not and will not work on MS Office 2013.
in the name GOD .
it's very bad.
please call Autodesk Company to solve this problem and release an update for "Spreadsheet Calculator 2014" as soon as possible.
thanks
it's very bad.
please call Autodesk Company to solve this problem and release an update for "Spreadesheet Calculator 2014" as soon as possible.
thanks
in any case please solve this matter as soon as possible.
it's very bad for a 2014 released software (such as Spreadsheet Calculator 2014) that can not compatible with a 2013 software (such as Excel 2013).
thanks
It is not a problem \ bug - it is software limitation.
Excuse me.
why exist this limitation for "Spreadsheet Calculator 2014" ? Why?
in any case it's a weakness.
Because the software architecture is old = based on all previous MS Offices architecture.
thanks awes.
but I install office 2013 on my pc and I don't have previous versions of Excel.it's a problem for me to use "Spreadsheet Calculator 2014" .
BTW
you autodesk has it wrong here "System requirements for Autodesk Robot Structural Analysis Professional"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21333507&linkID=12305695
For Robot™ Extensions Spreadsheet Calculator: Add Microsoft® Office Excel® 2007 or later
nothing about not working with 2013.
Thank you for letting us know about this issue. The text should be:
Additionally Microsoft® Office Excel® 2007 or 2010 (32 bits).
That has already been corrected on the site.
Try to run the procedure indicated in the attached document (mind the version).
Just to be clear: Most companies have switched to 64-bit and will not be able to run 32-bit programs - mine included. So we cannot use Spreadsheet Calculator? BR Jens
Am I missing something? I can run Spreadsheet Calculator 2014 on Win7 64-bit and Office 2007 32-bit.
in short : SC 2014 does not work on Office 64 bit.
