Spreadsheet Calculator 2014 - Robot Extension
20 REPLIES 20
Message 1 of 21
4071 Views, 20 Replies
in the name of  GOD .
hello.
I use Robot Structural Analysis 2014 and I see a problem in this version.
the "Robot Extension-Spreadsheet Calculator 2014" doesn't support "Excel 2013" unfortunately.
it's a big problem for Robot 2014 because the version of this product is 2014 and version of Excel is 2013.
This is a very big problem for Autodesk is that the 2014 version of your product, but with a 2013 version of software of another company isn't compatible.Smiley Frustrated
20 REPLIES 20
Message 2 of 21
Rafal.Gaweda
Unfortunately Spreadsheet Calculator does not and will not work on MS Office 2013.
Rafal Gaweda
Message 3 of 21
in reply to: Rafal.Gaweda
in the name  GOD .
it's very bad.
please call Autodesk Company to solve this problem and release an update for "Spreadsheet Calculator 2014" as soon as possible.
thanks
Message 4 of 21
Rafal.Gaweda
This is not a problem. This is software limitation.
Rafal Gaweda
Message 5 of 21
it's very bad.
please call Autodesk Company to solve this problem and release an update for "Spreadesheet Calculator 2014" as soon as possible.
thanks
Message 6 of 21
in any case please solve this matter as soon as possible.
it's very bad for a 2014 released software (such as Spreadsheet Calculator 2014) that can not compatible with a 2013 software (such as Excel 2013).
thanks
Message 7 of 21
Rafal.Gaweda
It is not a problem \ bug - it is software limitation.
Rafal Gaweda
Message 8 of 21
Excuse me.
why exist this limitation for "Spreadsheet Calculator 2014" ? Why?
in any case it's a weakness.
Message 9 of 21
Rafal.Gaweda
Because the software architecture is old = based on all previous  MS Offices architecture.
Rafal Gaweda
Message 10 of 21
awes
It's true that it would be nice to run programs with the latest features. But why make it a huge problem when you can use an older version of Excel with no lack in performance and reliability. There will certainly be an update and I'm quite sure you can do all your calculations in the meantime. Regards, Anders
Message 11 of 21
in reply to: awes
thanks awes.
but I install office 2013 on my pc and I don't have previous versions of Excel.it's a problem for me to use "Spreadsheet Calculator 2014" .
Message 12 of 21
Priitl220
in reply to: awes
BTW
you autodesk has it wrong here "System requirements for Autodesk Robot Structural Analysis Professional"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21333507&linkID=12305695
For Robot™ Extensions Spreadsheet Calculator: Add Microsoft® Office Excel® 2007 or later
nothing about not working with 2013.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Message 13 of 21
Thank you for letting us know about this issue. The text should be:
Additionally Microsoft® Office Excel® 2007 or 2010 (32 bits).
That has already been corrected on the site.
Artur Kosakowski
Message 14 of 21
in reply to: Artur.Kosakowski
Hi all
my robot extension have an error
please help me
Message 15 of 21
Artur.Kosakowski
Try to  run the procedure indicated in the attached document (mind the version).
Artur Kosakowski
Message 16 of 21
yes
Thanks pro very much
Message 17 of 21
Just to be clear: Most companies have switched to 64-bit and will not be able to run 32-bit programs - mine included. So we cannot use Spreadsheet Calculator?  BR Jens
Message 18 of 21
Rafal.Gaweda
Jens,
You are right.
Rafal Gaweda
Message 19 of 21
awes
Am I missing something? I can run Spreadsheet Calculator 2014 on Win7 64-bit and Office 2007 32-bit.
Message 20 of 21
Rafal.Gaweda
in reply to: awes
in short : SC 2014 does not work on Office 64 bit.
Rafal Gaweda
