Discussion Groups
Robot Structural Analysis
Distinguished Contributor
mpcloob
Re: Spreadsheet Calculator 2014 - Robot Extension
05-18-2013 05:45 AM in reply to: awes
in the name of  GOD .
thanks awes.
but I install office 2013 on my pc and I don't have previous versions of Excel.it's a problem for me to use "Spreadsheet Calculator 2014" .
Please use plain text.
Valued Contributor
Priitl220
08-04-2013 10:33 PM in reply to: awes
BTW
you autodesk has it wrong here "System requirements for Autodesk Robot Structural Analysis Professional"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21333507&linkID=12305695
For Robot™ Extensions Spreadsheet Calculator: Add Microsoft® Office Excel® 2007 or later
nothing about not working with 2013.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Product Support
Artur.Kosakowski
08-05-2013 08:12 AM in reply to: Priitl220
Thank you for letting us know about this issue. The text should be:
Additionally Microsoft® Office Excel® 2007 or 2010 (32 bits).
That has already been corrected on the site.
Artur Kosakowski
duchoabn
08-18-2013 08:36 PM in reply to: Artur.Kosakowski
Hi all
my robot extension have an error
please help me
Product Support
Artur.Kosakowski
08-19-2013 03:00 AM in reply to: duchoabn
Try to  run the procedure indicated in the attached document (mind the version).
Artur Kosakowski
duchoabn
08-19-2013 04:19 AM in reply to: Artur.Kosakowski
yes
Thanks pro very much
jd
New Member
jd
09-02-2013 06:05 AM in reply to: Artur.Kosakowski
Just to be clear: Most companies have switched to 64-bit and will not be able to run 32-bit programs - mine included. So we cannot use Spreadsheet Calculator?  BR Jens
Product Support
Rafal.Gaweda
09-02-2013 06:08 AM in reply to: jd
Jens,
You are right.
Rafal Gaweda
awes
09-02-2013 08:32 AM in reply to: Rafal.Gaweda
Am I missing something? I can run Spreadsheet Calculator 2014 on Win7 64-bit and Office 2007 32-bit.
Product Support
Rafal.Gaweda
09-03-2013 12:08 AM in reply to: awes
in short : SC 2014 does not work on Office 64 bit.
Rafal Gaweda
