I have installed Spreadsheet Calculator 2014 on my PC with W8 Pro x64 bits and Excel 2007 x32 bits but Spreadsheet Calculator 2014 doesn't recognise RSA 2014.
Cheers
Solved by PedroBiel. Go to Solution.
I can't see any problems with that. Could you provide more detailed description please? Is it the issue with the installation or data exchange? Other?
I run the RSA 2014 with some model, then the Spreadsheet Calculator 2014 from the RSA Add-Ins menu. When I introduce some command in the Spreadsheet Calculator I get only an information window which tells me 'The Autodesk Robot Structural Analysis is not running'.
I put in the example the bar no. 1, the load case no. 2 and I would like to get the value of the moment My, with no success.
The problem is solved.
I had an old version of RSA in my PC too and it seems the Spreadsheet Calculator 2014 locked for this old version and it couldn't find any result. I have uninstalled all the RSA programs and installed the RSA 2014 again.
By the way, is there a properly manual for the Spreadsheet Calculator? I know the two videos in youtube by Tomasz Fudala, but I am sure there is more that could be done.
