Discussion Groups
Robot Structural Analysis
*Expert Elite* | International Moderator
293 Kudos
Spreadsheet Calculator 2012 - insert formula
705 Views, 7 Replies
08-15-2011 08:30 AM
Hello there!
A problem occurred when trying to do one simple thing: insert formula with section info data.
Also I attached file. Thank you in advance!
Product Support
760 Kudos
Re: Spreadsheet Calculator 2012 - insert formula
08-17-2011 12:39 AM in reply to: Romanich
Most likely the section you try to import is not correctly recognized. Could you check if you have the same situation using e.g. HEA100 from one of the standard Robot section databases? Could you attach the Robot file you import bar 3 from please?
Artur Kosakowski
293 Kudos
08-17-2011 01:50 AM in reply to: Artur.Kosakowski
Dear Artur, thank you for your attention.
I found what the problem. This is bug. Just see picture:
Product Support
760 Kudos
08-17-2011 02:25 AM in reply to: Romanich
Please send me the rtd file. I would like to have a look at this issue. What is the section database you used - in case it is the user attach it as well. Thank you.
Artur Kosakowski
293 Kudos
08-17-2011 04:21 AM in reply to: Artur.Kosakowski
I attached rtd file.
Product Support
760 Kudos
08-17-2011 06:17 AM in reply to: Romanich
Please use H (height) and B (width) for concrete sections but D and BF for steel ones. This is how these section parameters are defined in Robot API.
Artur Kosakowski
293 Kudos
08-17-2011 06:24 AM in reply to: Artur.Kosakowski
Solution is manual correction of parameter?
Product Support
760 Kudos
08-17-2011 06:28 AM in reply to: Romanich
Currently yes, as only one type of the predefined formula is available in SC.
Artur Kosakowski
