Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Spreadsheet Calculator 2012 - EVar function
5 REPLIES 5
Romanich
845 Views, 5 Replies
I try to make example from manual:
But expression =EVar(_q*_L^2/8) returns 0. This function works only in this form: =EVar(_q)*EVar(_L)^2/8.
In addition, we have another bug: when I change value of q, for example, value in cell with Evar function return 0. Then, if I want to obtain the result, I go to Preferences, change any unit and press OK. In this case, the value will be updated.
Also I attached text file. Thanks.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
5 REPLIES 5
Artur.Kosakowski
in reply to: Romanich
EVar function works for a single registered cell only rather than for the whole expression. It searches for the registered in RESC cell and imports information about unit type converting it to the default unit. For the efficiency it is recommended to use EUToBase(...) function instead of EVar. EUToBase and EUToUser contain in their arguments all necessary information to convert values to the default units and vice versa to the display units.
It has to be remembered that each value in the expression has to be included in this formula so that EVar(-q*_l^2/8) is incorrect and is not supported.
Please try to use the EUToBase method instead.
Artur Kosakowski
Romanich
in reply to: Artur.Kosakowski
Thank you Artur. Syntax of the expression should be =EUToBase(_q*_L^2/8)  ?
Roman Zhelezniak
Artur.Kosakowski
=EUToBase(_q;"unit name")*EUToBase(_L;"unit name")^2/8
Artur Kosakowski
Romanich
In "unit name" I have to manually enter units? Can you modify & attach my file from first post? Many thanks in advance.
Roman Zhelezniak
Artur.Kosakowski
You can find the list of 'unit names' in 01units.cfg file (see the attached picture). In addition I'm attaching the modified xls.
Artur Kosakowski
