Discussion Groups
Robot Structural Analysis
*Expert Elite* | International Moderator
293 Kudos
Spreadsheet Calculator 2012 - EVar function
611 Views, 5 Replies
08-22-2011 12:43 AM
I try to make example from manual:
But expression =EVar(_q*_L^2/8) returns 0. This function works only in this form: =EVar(_q)*EVar(_L)^2/8.
In addition, we have another bug: when I change value of q, for example, value in cell with Evar function return 0. Then, if I want to obtain the result, I go to Preferences, change any unit and press OK. In this case, the value will be updated.
Also I attached text file. Thanks.
Product Support
760 Kudos
Re: Spreadsheet Calculator 2012 - EVar function
09-02-2011 06:37 AM in reply to: Romanich
EVar function works for a single registered cell only rather than for the whole expression. It searches for the registered in RESC cell and imports information about unit type converting it to the default unit. For the efficiency it is recommended to use EUToBase(...) function instead of EVar. EUToBase and EUToUser contain in their arguments all necessary information to convert values to the default units and vice versa to the display units.
It has to be remembered that each value in the expression has to be included in this formula so that EVar(-q*_l^2/8) is incorrect and is not supported.
Please try to use the EUToBase method instead.
Artur Kosakowski
293 Kudos
09-02-2011 07:44 AM in reply to: Artur.Kosakowski
Thank you Artur. Syntax of the expression should be =EUToBase(_q*_L^2/8)  ?
Product Support
760 Kudos
09-06-2011 12:48 AM in reply to: Romanich
=EUToBase(_q;"unit name")*EUToBase(_L;"unit name")^2/8
Artur Kosakowski
293 Kudos
09-06-2011 12:57 AM in reply to: Artur.Kosakowski
In "unit name" I have to manually enter units? Can you modify & attach my file from first post? Many thanks in advance.
Product Support
760 Kudos
09-06-2011 01:56 AM in reply to: Romanich
You can find the list of 'unit names' in 01units.cfg file (see the attached picture). In addition I'm attaching the modified xls.
Artur Kosakowski
