When I open spreadsheet calculator in version 2012, it only comes up as a Demo Version.
When i open it in 2013, only the excel page opens, with no libraries, etc. There is nothing prompting me to select an analysis.
Do I need to do separate registration to use the Spreadsheet Calculator?
Good morning,
try to run as administrator all the ESOP app in the folder:
C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\RESC
For 2013:
- Install SC Content if not installed
- copy files from attached zips to correct SC folders.
Hi everyone,
I can't use the libaries in Spreadsheet Calculator for Robot Structural Analysis 2014, as you can see in the following picture:
I've downloaded and installed the spreadsheet for 2014.
Attached on this mail the diagnosis report of the ESOP Start. What can I do to fix this issue?
Greetings at all.
Good morning Rafal,
I've downloaded the and installed SC 2014 content in this folder:
C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2014\RESC\Engineering\lib
I have Office 2007 with this info capture:
I don't know if it's 32 or 64 bit. How can I check this, the software was pre installed on PC when I purchase it.
Greetings
I recently made a format in my PC so i had to re-install ARSA2013, but i face the same problem with SC as described above, i.e with no libraries (actually it isn't the 1st time that happens to me, as far as i remember i hade the same problem many times in the past..). I did the "usual" procudure of unregistering- registering the componets (see attached) but it dididn't work. I am not sure if i did it well as the last time i did it was 1-2 years, so which components should we unregister and then register?
It is included in the CD, isn't it?. The existence of RESC file doesn't proove that?
When version ARSA2013 came out for the first time, i was subscribed but now i am not. Do you mean that now that i am just reinstalling ASRSA2013 i am not able to use SC..!? That's not fair at all...
Never mind, i fixed it... I played with the unregister-register procedure and then opend the 5 Esop files as administrator and it was o.k...
Kindly put through for the meaning of the following denotations for internal forces in Robot structural calculation sheet.
N,Ed
Nc,Rd
Nb,Rd
Thanks in anticipation of your feedback.
