I can´t figured out how Robot calculate the punching in a spread footing. The code is EN1992-1.
Punching force (Robot) = 493.099 kN vs 567.87 kN (spreadsheet)
Any help would be greatly appreciated.
A.Santos (Portugal)
Solved by Artur.Kosakowski. Go to Solution.
Solved by 1970780. Go to Solution.
Could you attach the rtd file with this spread footing?
Hi
Thanks for your help, I attach the xls file and rtd file
A.Santos (Portugal)
The value from Robot 2015 SP3
the critical perimeter now is 3,70m, but should be 4,60
there is some reason to this?
how the robot calculates this value ?
A.Santos (Portugal)
See the attached doc file.
