Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Spiral stair slab
35 REPLIES 35
Message 1 of 36
sergey.churilov
5428 Views, 35 Replies
Spiral stair slab
Hello to all,
I was wandering what is the easiest way to model spiral stair slab (or car ramp) in ARSA. (see example pic)
Can you please share your ideas?
Thanks.
35 REPLIES 35
Message 2 of 36
Romanich
in reply to: sergey.churilov
Hi Sergey,
easiest way is use this functionality:
Draw line with your stair width and then go to this menu.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 36
Step 1 and then step 2 Smiley Happy
Artur Kosakowski
Message 4 of 36
Romanich
Just watch my video, please.
Roman Zhelezniak
Message 5 of 36
Can ARSA generate the reinforment for this stair? (Free, without the walls as support)
thanks in advance
Marcelo
Message 6 of 36
Romanich
Yes of course, but only required  reinforcement.
Roman Zhelezniak
Message 7 of 36
athurD
Thansk.
I do try . But do not.
So it is bar or panel
Please.
Message 8 of 36
Romanich
in reply to: athurD
Vertical - bar, horizontal - line.
Roman Zhelezniak
Message 9 of 36
Hi.
How object modification can be activated in substructure modification of edit menu. Mine dosen't appear at all.
Message 10 of 36
What is the structure type you are working with? Is it a plate?Can you make the screen capture of the menu that is displayed for you?
Artur Kosakowski
Message 11 of 36
The type of structure is Building Design.
Message 12 of 36
You have two possibilities:
1. Temporarily change the model type to Shell (Geometry > Structure type) and access these commands
2. Add them to menu as described in:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Moving-loads/m-p/3740653
or
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Panel-Cuts/m-p/3181558
Artur Kosakowski
Message 13 of 36
Thanx
Accept as answer
Message 14 of 36
Hi to you all
I was searching the internet about how to model spiral stairs in robot, then I found this group, i try to do the same steps you explain but unfortunately it doesn't work, so i hope if you could explain it more clearly especially the part related to drawing a horizontal line = stair width (what is the command you use in robot), by the way i use polyline command & it doesn't work
thanks in advance
Message 15 of 36
Pawel.Pulak
See the video posted by Romanich in the message 4 - he has made it for horizontal line or polyline.
Pawel Pulak
Technical Account Specialist
Message 16 of 36
in reply to: Pawel.Pulak
Hi
Thank you for your reply but I have seen the video in message four it starts with using the object modification without showing how the horizontal line was drawn.
my best regards
Message 17 of 36
It's not so difficult.
Menu Bar--------------->Geometry------------->objects--------------> polyline - contour.
Choose Polyline.  Draw a line.  Press apply.
Did you actually try this before posting the question?
Tony
Message 18 of 36
in reply to: HoshangMustafa
of course I try this command its not a new to me but when I draw the line or polyline there is nothing appear on the screen , and of course I change my display settings to make this line appear but there is nothing on the screen.
thanks
Message 19 of 36
Pawel.Pulak
See this video showing some operations preceding the operations shown by Romanich, i.e:
1/ selecting shell structure,
2/ defining vertical bar (used only for snapping) and horizontal polyline in XZ plane (Y=0)
3/ switching to 3D view
I have defined the polyline snapping to grid in planar XZ projection. If you define it by the input of coordinates it may be not displayed if it is out of the working plane.
Pawel Pulak
Message 20 of 36
Thank you very much for the video you have made, I have done every step in the video but the problem is that the polyline that i draw dosn't appear on the screen and i use the grid to pick the points for the polyline not coordinates.
If i use contour to draw it appears the lines but if i use (polyline or line) there is nothing appear on the screen.
I keep searching the net looking for a solution to this problem but i didn't find any thing
best regards
