Discussion Groups
Robot Structural Analysis
Active Member
0 Kudos
Re: Spiral stair slab
10-27-2013 08:27 AM in reply to: HoshangMustafa
Thank you very much for the video, I do every step in the video until I reach to the polyline command I pick the points using the grids on the screen (no coordinates) and there was nothing drawn by this command
I don't really know where is the problem, if i choose contour the lines appear but i choose line or polyline there is nothing on the screen.
my best regards
Distinguished Contributor
17 Kudos
10-27-2013 11:56 PM in reply to: ce_ng2012
Have you tried reducing the graphic hardware acceleraction level?
Tools --> Preferences --> View Parameters
Reduce "Display acceleration" slider, restart Robot and then try it again.
INTELIKA
Mirko Jurcevic M.Eng.
INTELIKA d.o.o.
www.intelika.hr
Active Member
0 Kudos
10-28-2013 12:37 PM in reply to: ce_ng2012
Hi to you all
Thank you Eng. Mirko Jurcevic it works at last.
Valued Contributor
13 Kudos
10-03-2014 10:52 AM in reply to: Romanich
