Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Mohammed_Ata
454 Views, 5 Replies
Spiral beam
How can i generate spiral beam for the spiral slab (stairs) ?
it is attached / spiral slab .
5 REPLIES 5
As a chain of bar elements from one node to another.
Artur Kosakowski
Mohammed_Ata
in reply to: Mohammed_Ata
please , attach me a printscreen showing this .
Simon404
Once you have the panel meshed, just draw bars from node to node along the edge.
Change the parameters of the mesh if you want the beam less linear.
Ensure the bar releases are fixed.
Done.
Mohammed_Ata
ok i did it , thank you so much .
how can i make them as one bar ?
Simon404
Go to: design tab - Steel Members design Options - Members/Groups Defenition
Click New, to create a new bar number
Add the bar numbers you want as the super bar into the, bar list.
Add name of super bar.
Change member type.
Click OK.
Read the help file regarding C. Groups (Code Groups), but your unlikely to need it at this stage.
