Hello, I'm trying to do an spectral analysis on the program, and I have a .txt file with all the points of my spectrum, but, when I try to open the text file RSA doesn't recognize the file (or points, I don't know).
I have readed this http://docs.autodesk.com/RSA/2013/ENU/index.html?url=filesROBOT/GUID-3371A1D6-F14D-4208-BB69-4FFC96F...
I just want to know how to open the .txt file
I add two kind of text file, one separates the columns with a coma and other with point.
Please, help me with this little inconvenient, thank you
Solved by bartolome1819. Go to Solution.
Solved by t.sautierr. Go to Solution.
Your file has to be a .spe and not a .txt so rename it.
You can find examples of spectrums in the RSA folder, open it with notepad and respect the syntax, you should be able to create and import the one you desire.
Link to the example in Robot Folder :
C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Cfg and look for the .spe files.
