Discussion Groups
Robot Structural Analysis
Valued Mentor
tony.ridley
Accepted Solution
Spectral analysis
681 Views, 18 Replies
03-11-2012 04:12 AM
When running spectral analysis;
I go to Spectral --------->direction definition---------->Resolution of a force into directions--------->Newmark Combination.  I'm only checking X and Y directions, so I choose Group 1 and Group 2.
Robot then automatically assigns 4 CQC combinations as shown in the next picture.
Questions:
  1. Why is only Y direction given a negative sign.  I would expect to see negative X somewhere too.
  2. When the spectral analysis is run (say X direction only), does the active mass act on the structure in both +X and -X?
  3. If the mass in X acts both positive and negative, then I guess it's the same for the Y direction too.  So why the need for a neg Y case?
  4. If I double click on the generated combinations, I can choose "signed".  I guess this automatically runs the combination for a variety of -ve and +ve signs for X and Y.  If I guess coreectly, then I only need two linear signed combinations and not four, no? (+- 100%x +- 30%y, +-30%x +- 100%y).  If I guess wrong please can you explain it to me.
  5. I read from help menu that combination sign "main mode" defaults to zero and thus all signs for all modes are taken into account.  By nominating a main mode, am I still getting +ve and -ve signing?
  6. Have I missed something and am completey on the wrong track here?
Tony
Please use plain text.
Valued Mentor
tony.ridley
Re: Spectral analysis
03-11-2012 03:38 PM in reply to: tony.ridley
Question 7:
If I manually define a combination say 1.0x - 0.3y, will I get the same result as the automatically generated case from the Newmark combination?
Product Support
Artur.Kosakowski
03-12-2012 12:46 AM in reply to: tony.ridley
Tony,
Robot automatically generates only half of combinations (only these with positive X). As these combinations are then intended to be combined with other load cases it is assumed that they will be added with both positive and negative load factors e.g. 1.0* case 7 and -1.0* case 7. The same is done (automatically) when you use automatic code combinations. Masses act in both directions but only one load case for a given direction is generated (only one X or Y) therefore you have to create combinations that have a negative load factors for them. By default when you use quadratic combination formulas the signs of e.g. bending moments will be only positive. To have them 'behaving' as these from 'standard' load cases you have to decide which mode is to be reference for its signing.
Artur Kosakowski
Product Support
Artur.Kosakowski
03-12-2012 12:51 AM in reply to: tony.ridley
Question 7:
Yes. There is no difference if a combination is created manually of automatically.
Artur Kosakowski
*Expert Elite* | International Moderator
Romanich
03-12-2012 01:12 AM in reply to: Artur.Kosakowski
Artur,
Robot don't use cases 6...9 (linear combination in Tony's example). Only case 4 and 5 will be added to automatic combinations with positive and negative load factors. Maybe it's bug?
P.S. If I use quadratic combination, I have the same results.
Product Support
Artur.Kosakowski
03-12-2012 01:40 AM in reply to: Romanich
They should be
Artur Kosakowski
Valued Mentor
tony.ridley
03-12-2012 02:13 AM in reply to: Artur.Kosakowski
So if I choose a mode (mode 2 for Y direction in my model) in the analysis type---->combination sign, will my moment diagram behave as i would expect for a regular static analysis?
Product Support
Artur.Kosakowski
03-12-2012 02:20 AM in reply to: tony.ridley
Correct. Usually the main criterion to select such modes is their contribution to participation mass for given direction.
Artur Kosakowski
Romanich
03-12-2012 03:13 AM in reply to: Artur.Kosakowski
Thank you, Artur. I've solved this problem.
Valued Mentor
tony.ridley
03-12-2012 03:21 AM in reply to: Artur.Kosakowski
OK.  So when I put on the results, should I choose mode 2 only, or select CQC, as I have already chosen mode 2 as the main mode / signed mode?
