In Eurocode 8 I need to combine the earthquake horizontal with the vertical (For example Y +0.30X +0.30Z). The spectrum used in x and y is different from what is used in z.
In a spectral analysis can tell you how to combine the two earthquakes spectral different?
Solved by Artur.Kosakowski. Go to Solution.
In the exactly the same way. You define the X and Y cases with one spectrum and the Z with another. Then you create quadratic combination with the corresponding load factors for each of these spectral cases.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
OK
HOW DO IT?
HOW DO IT?
Please check:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Spectral-analysis/m-p/3366531
