SP4 ROBOT 2015
SP4 ROBOT 2015
iegia
Message 1 of 16
SP4 ROBOT 2015
iegia
Hello
After installing SP4 for ARSAP 2015, I can´t open  "Provided Reinforcement of Rc Elements" after selecting a node. The software crashes and is not responding. Yesterday I was able to calculate the job, with the footings. I have done new simple jobs to prove and it crashes to click  "Provided Reinforcement of Rc Elements".
I have installed the SP4 in other computer and I have not the same problem, i can open "Provided Reinforcement of Rc Elements". But the main menu for the footings design disappers as you can see in the pics. You must restart the program in order to recover the menu.
How can I fix this problem? Can I unistall the SP4? I installed the SP4 because there were several  improvements in RC Members Design.
Thanks in advance
Replies (15)
Message 2 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
You are kindly requested to uninstall SP4.
SP4 is not available to download anymore.
Rafal Gaweda
Message 3 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
PLease send us this rtd file
Tools \ Customize \ Open layouts from template.
Rafal Gaweda
Message 4 of 16
iegia
Hello
To uninstall the sp4, have I to uninstall the whole sorfware a reinstall it with SP3?
I could send you the file, but the problem occurs with all the files.
Message 5 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
@iegia wrote:
Hello
Uninstall SP4 only.
So it mean it is rather not related to SP4.
Clear cfgusr folder before next robot start, loae the file and check
If it does not help: clear cfgusr folder before next robot start + open file in repair mode.
Rafal Gaweda
Message 6 of 16
iegia
How can I uninstall only SP4?, when I go to Panel Control I can only uninstall ARSAP2015
Message 7 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 8 of 16
iegia
Thank you Rafal
I have only uninstalled SP4 and "Provided Reinforcement of RC elements" works again. I haven´t cleared cfgusr folder.
Thank you very much
Iñaki Egia
Message 9 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
Please send my one of your files.
Rafal Gaweda
Message 10 of 16
iegia
Hello Rafal
I send you the file
https://www.filemail.com/t/35927821d44d41e49cfcfe9cc5f1150c
Take this opportunity to talk to you about two things:
-When i send the file to revit structure, i have to delete the stories, to avoid an error "colum with lenght 0". It makes nothing is exported.
-Calculations -ANSI/AISC 360-10- the menbers with torsión, it checks combination of Axial, bending Y and Z. It checks shears stress but it doesn´t check Von Mises stress combination of normal stress and shear stress. (for example bar 251).
Thank you in advance
Message 11 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
As far as we know such check is not required by code unless it is HSS section
Rafal Gaweda
Message 12 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
Could you be so kind and record the movie (for eg by autoddesk screencast) how you work \ what you do becasue we were unable to reproduce  your issue.?
Rafal Gaweda
Message 13 of 16
iegia
Hello Rafal
I have recorded this movie (it´s my first time)
http://autode.sk/1xrQObO
When SP4 was installed, after click Ok in the dialog box "Spread footing Paremeters of RC elements" The software crashed was not responding.
Message 14 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
Thanks for reporing. We have to check it.
Revit file : http://we.tl/4ktkhOfe1H
Rafal Gaweda
Message 15 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
Removing everything from widows %temp% folder helped.
Rafal Gaweda
Message 16 of 16
iegia
Thanks for all the help given
