Some warning in calculation.
Hi admin,
I have finished my model in Revit Structure and then export to Robot, but after the calculation, there were some warnings:
"The load has not been distributed correctly"
"Linear load has not been applied to a panel"
I think the first problem, the reason was  I defined wall in Revit for applying wind load, after export to Robot, I change those walls to cladding.
And the second one, the reason was I define all concrete slab become rigid-diaphgarm and mesh with element size 1m.
I just only do those works on robot.
Please check the attched model and send me the feedback.
Many thanks.
https://drive.google.com/file/d/0B6gBiwcLbewhNF9lNUR4T3B4SlU/view?usp=sharing
Rafal.Gaweda
Autodesk Support
Autodesk Support
If you look at "Load distribution regions" display everything seems to be OK.
So you may ignore it.
See hints here:
http://forums.autodesk.com/t5/robot-structural-analysis/linear-load-has-not-been-applied-to-the-pane...
http://forums.autodesk.com/t5/robot-structural-analysis/linear-load-has-not-been-applied-to-a-panel/...
http://forums.autodesk.com/t5/robot-structural-analysis/linear-load-has-not-been-applied-to-panel/m-...
Rafal Gaweda
Thank you for your support Rafar.
I have read all about these 2 warning. But I think my problems are diffirent.
The first " The load has not been distributed correctly, there are no objects or elements carrying the load overlap". It happened to all claddings and slabs.
It was occur when I change the wall that were applied wind load to cladding  by using : Geometry/ Additional Attributes/ Load distribution - Claddings
and define all slab to rigid diaphragm.
The second" Liner load has not been applied to a panel". It only happend to the 5th floor, although the rest floor have similar loads.
Could you please take a look to my model attached and give me the feedback. 🙂
Thanks a lot!
Sorry I had a mistake. The second warning happened after I defined all slab to rigid-diaphragm, all linear loads I applied on slab became " has not been applied to a panel". Before that, there was no warning about this.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Ignore them or mesh slabs
Example:
Rafal Gaweda
