Robot Structural Analysis Forum
Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
Did you mean:Ā
Soil pressure
20 REPLIES 20
Message 1 of 21
athurD
4556 Views, 20 Replies
Soil pressure
You could tutorial video Soil pressure retaining wall.
retaining wall problem ?????
20 REPLIES 20
Message 2 of 21
Rafal.Gaweda
in reply to: athurD
Example here:  http://screencast.com/t/n1x4jDj3k , I have used predefined soils modified, entered only data you gave us.
Rafal Gaweda
Message 3 of 21
athurD
in reply to: Rafal.Gaweda
Thanks you. RG_Adsk
Verry Good.
Message 4 of 21
athurD
in reply to: athurD
Hi. I is prolem. I is attachment Math manual
Message 5 of 21
athurD
RG_Adsk
Please help me?
Message 6 of 21
Rafal.Gaweda
in reply to: athurD
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-6774D010-E6B5-430D-9379-678ECB43245-479.htm
"Data that specifies the soil work that results from the displacement of a retaining element. The displacement is defined using the rotation element r, which is assumed to be approximately equal to: f/H (wall top displacement / element height). The soil work mode can be determined as:
- Active pressure Ka -> Ļa ā‰¤ Ļ < 0
- Static pressure Ko -> Ļ = 0
- Passive pressure Kp -> 0 < Ļ ā‰¤ Ļp"
so specify f/H as -0.406 or 0.406 or calculated f/H
Rafal Gaweda
Message 7 of 21
athurD
Thanks you.
But I Comparison of hand and the results of Robot.
Message 8 of 21
athurD
in reply to: athurD
please help me???
Message 9 of 21
Artur.Kosakowski
in reply to: athurD
Artur Kosakowski
Message 10 of 21
athurD
in reply to: athurD
Thanks Artur.Kosakowski
But I not do.
You can tutorial video?????
THanks Artur.Kosakowski
Message 11 of 21
Artur.Kosakowski
in reply to: athurD
Here you are.
Artur Kosakowski
Message 12 of 21
athurD
in reply to: Artur.Kosakowski
Thanks you Artur.Kosakowski
Message 13 of 21
in reply to: athurD
HI ALL
I have an error when use special load
pl see picture
in this link my file
http://www.mediafire.com/?100h19r4zgi10tp
thanks
Message 14 of 21
Artur.Kosakowski
See the attached picture.
Artur Kosakowski
Message 15 of 21
thanks you
but error display again
thanks you very much
Message 16 of 21
Artur.Kosakowski
Expand the load selection list and select one of the loads. This should result in display of this load at the top of the soil load dialog. Then follow the steps indicated in my previous answer.
Artur Kosakowski
Message 17 of 21
thanks artur
can you guide me calculation retailing wall in excersice below use robot
THANKS YOU
Message 18 of 21
Artur.Kosakowski
In general Robot is not intended for this kind of calculations. It is due to the fact that you need to define some boundary conditions (supports) to converge the analysis (that cannot be achieved based on finding the equilibrium of applied loads with no supports defined).
Artur Kosakowski
Message 19 of 21
tks autur
I am learing robot and revit structure. Can you share for me a project completed in revit structure . that is drawing construction? I use it for learning revit
my email: duchoatla@gmail.com
Message 20 of 21
Artur.Kosakowski
Please use the dedicated Revit Structure forum for that kind of requests. Thank you.
Artur Kosakowski
