I am attempting to model an underground cylindrical reinforced conrete water retaining structure. I am unable to apply a soil load to the outside of the cylinder. I have done a simpler example with a square structure, however when I complicate the problem and make it a cylinder I am unable to get get the soil load to work. To build the strucutre I made the circular floor slab and then extruded the walls up from a circle drawn at the same level as the floor slab. (PLease see the attached file to see exactly)
Any help would be greatly appreciated, or if your feeling generous a tutorial for tihe initial stages would be really useful.
Thanks, Leo
Solved by Artur.Kosakowski. Go to Solution.
Try to follow the steps indicated on the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
