When I'm trying to calculate required reinforcement for slabs, as well as beams. I get the folowing error: "Required types are not ascribed to SLS combinations. Calculations may be incorrect."
Whats wrong?
Solved by Rafal.Gaweda. Go to Solution.
As I wrote the algorithm is not optimized for running SLS cases only but in general:
1. Keeping cracks under the defined limit may require more reinforcement than is required to fulfill strength requirements. In addition you may see the increase of reinforcement if you mark reduction of the deflection by increase of (SLS) reinforcement.
2. In may be the attempt to increase 'cracked' slab thickness stiffness for the correction of the deflection or compression reinforcement in case you have very high bending moment.
