Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
SLS combination
22 REPLIES 22
Message 1 of 23
Jorgew09
5752 Views, 22 Replies
SLS combination
When I'm trying to calculate required reinforcement for slabs, as well as beams. I get the folowing error: "Required types are not ascribed to SLS combinations. Calculations may be incorrect."
Whats wrong?
22 REPLIES 22
Message 2 of 23
Artur.Kosakowski
in reply to: Jorgew09
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/sizing-slab/m-p/3280315/highlight/true#M2093
Focus on the massage 8 in particular.
Hope this helps.
Artur Kosakowski
Message 3 of 23
Jorgew09
in reply to: Artur.Kosakowski
Still can't find whats wrong.
Message 4 of 23
Rafal.Gaweda
* Required types are not ascribed to SLS combinations
Please make sure that creating combinations you assigned the appropriate type as required by the RC design code you selected (see the attached picture).
For emaxple : for EC code for SLS check you have to create \ use SLS:QPR combinations
Rafal Gaweda
Message 5 of 23
TorgrimO
in reply to: Rafal.Gaweda
I'd like to ask a question about this: If i choose SLS instead of SLS:QPR, what would the difference be in the result for a concrete slab and why? (Using eurocode with norwegian NA).
Message 6 of 23
Rafal.Gaweda
in reply to: TorgrimO
Live Loads factor are different in combination definitions
Rafal Gaweda
Message 7 of 23
TorgrimO
But if I define all the factors myself in the load combination table it won't matter which one i choose? Theoretically I can call it ULS?
Message 8 of 23
Rafal.Gaweda
and then program assumes them as QPR for SLS check
Rafal Gaweda
Message 9 of 23
Hi I'm having the same error message but I'm designing to British Standards rather than Eurocode so I don't have the option to set the combination to SLS:QPR (and presumably I'm not meant to). I'm using manual combinations. Does anyone have any other ideas as to what could be the cause of the error message?
See attached pictures.
Message 10 of 23
Rafal.Gaweda
Are you sure you set BS not BS EN code for RC design?
Send us the file
Rafal Gaweda
Message 11 of 23
Message 12 of 23
Rafal.Gaweda
Rafal Gaweda
Message 13 of 23
How do I change that apart from in job preferences?
Message 14 of 23
Rafal.Gaweda
Create new reinforcement label and apply it to panel
Rafal Gaweda
Message 15 of 23
Thank you 🙂
Message 16 of 23
Andyf88
Can anyone help please?
I am doing the design of a slab in a similar way as described here.
1. When I do the design according the ULS the results for reinforcement seem to be fine (see the first figure below). But, when I do the disgn according the SLS I get reinforcement even at the bottom (negative) side of the slab under the column (see second figure below). Why does SLS give me reinforcement on that side, we do not get that usually as it is also backed up by the results from the ULS design?
2. Am I supposed to run both ULS and SLS at the same time? Because if I do that Robot gives me only the max reinforcement which is that from SLS.
Message 17 of 23
Artur.Kosakowski
in reply to: Andyf88
Yes, you should include both ULS and SLS cases rather than SLS alone (but you may run reinforcement design for ULS only).
Artur Kosakowski
Message 18 of 23
Andyf88
Do you mean like in the figure below?
You said :"you should include both ULS and SLS cases rather than SLS alone (but you may run reinforcement design for ULS only)."
The way given in the figure below means that I run design for both SLS and ULS, doesn't it? How do I run reinforcement design for ULS only? And which is the right way to do it - both SLS and ULS or separately?
Message 19 of 23
Artur.Kosakowski
Correct.
Leaving SLS case selection field empty.
The prior one.
Artur Kosakowski
Message 20 of 23
Andyf88
Many thanks Artur.
