Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
SLS combination
22 REPLIES 22
Message 1 of 23
Jorgew09
5753 Views, 22 Replies
SLS combination
When I'm trying to calculate required reinforcement for slabs, as well as beams. I get the folowing error: "Required types are not ascribed to SLS combinations. Calculations may be incorrect."
Whats wrong?
22 REPLIES 22
Message 21 of 23
Andyf88
in reply to: Jorgew09
Sorry, any idea why SLS when acting alone, compared to ULS, gives:
1. higher reinforcement
2. and why it gives reinforcement at the bottom of the slab in the area under columns, (usually expected top reinforcement only in this area)?
Thank you.
Message 22 of 23
Artur.Kosakowski
in reply to: Andyf88
As I wrote the algorithm is not optimized for running SLS cases only but in general:
1. Keeping cracks under the defined limit may require more reinforcement than is required to fulfill strength requirements. In addition you may see the increase of reinforcement if you mark reduction of the deflection by increase of (SLS) reinforcement.
2. In may be the attempt to increase 'cracked' slab thickness stiffness for the correction of the deflection or compression reinforcement in case you have very high bending moment.
Artur Kosakowski
Message 23 of 23
Andyf88
in reply to: Artur.Kosakowski
Artur,
Thank you very much, very helpful.
