Discussion Groups
Robot Structural Analysis
Member
0 Kudos
Slow meshing
469 Views, 5 Replies
11-10-2011 07:59 AM
Problem in the following... On the big problems very slowly meshing separate plates or walls. Not all building entirely, and even separate elements. How it to solve?
Product Support
1,303 Kudos
Re: Slow meshing
11-14-2011 12:33 AM in reply to: MaxBob
Hello
Try Meshing options as shown below (settings of greyed out fields are also important )
If it does not help please share your model or part of your model to check
Rafal Gaweda
Member
0 Kudos
Re: Slow meshing
11-15-2011 11:46 AM in reply to: Rafal.Gaweda
Thanks big for the answer! I will try! Partially I have solved a problem, namely have made model correction. But there was other problem: process of creation of settlement model goes normally, attributes are appointed, loadings are put, but in the end there is a ROBOT lag, and the model as a result isn't created. The model even without loadings isn't created, in the end hangs. What can it be? By the way, the file with geometry occupies 70 Mb.
Product Support
1,303 Kudos
Re: Slow meshing
11-15-2011 10:34 PM in reply to: MaxBob
Check Private Message
Rafal Gaweda
Product Support
1,303 Kudos
Re: Slow meshing
11-21-2011 01:16 AM in reply to: Rafal.Gaweda
I think you will get ~500000 FE model so it will be hard to work with it.
I suggest different approaches:
* General remark - in your case mesh slabs first, then cores (walls)
- change meshing parameters to get smaller number of finite elements
- if you are not interested in slabs results so far (eg designing cores)  use diaphragms instead of meshed panels:
-  if you are interested in more accurate results on some slabs – mesh only them or mesh them with more refine mesh than other panels
Rafal Gaweda
Member
0 Kudos
Re: Slow meshing
12-05-2011 11:36 AM in reply to: Rafal.Gaweda
With your help has understood this question :smileyhappy: Thanks!
