I have a concrete slab and I would like to add an horizontal force, however in a slab project i can´t do it...
Can I modify the type of slab´s calculation? Or Robot doesn´t do that?
Thanks in advance.
Solved by dimogrec. Go to Solution.
No in structure type "plate design" you can't add horizontal forces-loads (as far as I know)
Try changing structre type (Geometry->structure type) to "shell design" and then you will be able to add horizontal in plane forces-loads
Yes, I did it however the shell calculation doesn´t give me consistent horizontal results in term of deformation and tension.
