Good Morning / Evening
Is there any explanation to the differences between reinforcement section indicated in the attachement ( medium stairs landing ).
What would be the section you will adopt ? and what would be the reasoning adopted in similar case ?
Thank you.
Solved by faisal.aaouatif. Go to Solution.
I would first check the deformation and distribution of bending moments (and in-plane forces if included) to understand the behaviour of the model.
As far as I can see the bending moments map corresponds with the distribution of reinforcement.
As the obtained peeks are in points you mat tyr to dsitribute (average) reinforcement along certain width of a panel. You may also think about some other solutions such as e.g. hidden beam.
Ok thank you Rafal.
This is was ive done but the controler office is from another planet ...
