Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
JIHADTM
675 Views, 1 Reply
slab punching
I'm checking the slab punshing by using robot 2013 using ACI sode,  I defined from the design tab menu  reinforcement wall/slab options code parameter) the properties of the rc slab (see attachement) as follow:
Concrete cover = 30mm.
However when I calculated the punching by software, I found out that the cover has been taken equal to 50mm ????.
please clarrify how I can control determination of concrete cover used by software. See attachement.
1 REPLY 1
Artur.Kosakowski
in reply to: JIHADTM
Check what reinforcement label you actually assigned to panel 21. Looking at the picture you attached I got the feeling that you compared reinforcement label that was assigned to this panel (provided reinforcement) with the one that wasn't (required reinforcement).
Artur Kosakowski
