Discussion Groups
Robot Structural Analysis
0 Kudos
slab punching
309 Views, 1 Replies
10-16-2012 12:28 AM
I'm checking the slab punshing by using robot 2013 using ACI sode,  I defined from the design tab menu  reinforcement wall/slab options code parameter) the properties of the rc slab (see attachement) as follow:
Concrete cover = 30mm.
However when I calculated the punching by software, I found out that the cover has been taken equal to 50mm ????.
please clarrify how I can control determination of concrete cover used by software. See attachement.
Product Support
756 Kudos
Re: slab punching
10-16-2012 12:50 AM in reply to: JIHADTM
Check what reinforcement label you actually assigned to panel 21. Looking at the picture you attached I got the feeling that you compared reinforcement label that was assigned to this panel (provided reinforcement) with the one that wasn't (required reinforcement).
Artur Kosakowski
