I have a slab supported by beams.
In the beam 7 the maximum deflection is 21 mm (attachment) in the same point the maximum delfexion of the slab is 75 mm (attachment)
How is it possible if the slab is supported by the beam?
How I fix the problem ?
thank you
Solved by Rafal.Gaweda. Go to Solution.
Thanks Ahmed, but I ask for the slab deflexion in required reinforcement module (75 mm) it’s biggest than support steel beam, please see the attachments in my first post.
I think this is not possible have more deflexion in the same point in slab than the support beam
In attachment you can find a more developed model, now I have only one slab, the supports beams are 100 mm under, the slab and supports beams are connected every mesh joint by rigid links and de result is the same.
“in de module concrete required reinforcement, the deflexion of the slab in service load state is more than the support beam”
What is wron in my model?
thanks
