Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
slab deflection in column zone
7 REPLIES 7
Message 1 of 8
peter-rc
1308 Views, 7 Replies
i get slab deflection in column zones.
i modelled my building without foundation and assigned fixed support to columns.
why i get such error? i checked every steps but i can not find,
could you pls help me
thanks
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
in reply to: peter-rc
Try to display the deformation of the whole building looking at its side. This should give you the indicate where to look for the cause. Otherwise send us your model.
Artur Kosakowski
Message 3 of 8
peter-rc
in reply to: Artur.Kosakowski
First of all, thanks for your attention.
i couldn't find any clue,here may screen view.
i also want to send you model but size is to much (with results 52mb, without results 24 mb)
Message 4 of 8
Refaat
Dear Peter-rc
Kindly , take a look to  the attached capture
Refaat
Message 5 of 8
Artur.Kosakowski
My assumption is that this is the effect of shortening of columns at each of levels (much larger than walls) under the applied load. Such effect does not exists for gravity design by hand when you assume that columns are the supports that do not move vertically.
You can try to leave only one of the top slab with its supporting wall and columns (and supports at their bottoms) and check the slab deflection - this is the approach I would use for slab design.
You can also try to increase E of the columns and reduce their ability to 'attract' bending from slab using some elastic releases.
Artur Kosakowski
Message 6 of 8
peter-rc
Hi Artur and Refaat,
i assigned rigit link (only Uz direction) to every column and now everything is ok..
thanks for your help
Message 7 of 8
Refaat
Dear Peter-rc
Please , you have to take care if (you use vertical rigid link only Uz)and you have any later loads on your structure because the axial force distribution will be effective as you see in the attached capture .
As well , I would like to draw your attention that there is big difference between node displacement and the slab deflection . The slab deflection related to the element (slab) itself while the node displacement related to the movement between the nodes themselves.
Refaat
Message 8 of 8
peter-rc
in reply to: Refaat
Hi Refaat,
You are right, my column loads (axial) are false. You can see differences.(cap5-without rigit links. cap6-with rigit link)
N, M, Q and reinforcement values are wrong for columns. there is also interesting point; reactions are ture....
i will delete lateral forces, i wish i will get true axial forces..
