Hi
I have a slab with depressions above supports making the slab thickness as little as 100mm.
Therefore, I want only one layer of reinforcement and consider bending. How is this done?
With the settings below I get a warning seen at the bottom which I am unsure how effects my structure.
Kind regards
Peder
Solved by pevelor. Go to Solution.
Not possible.
Send me model to check.
What do you mean by "Not possible"?
I thought compression/tension was used only for walls without bending out of plane.
Doesn't 'compression/tension' relate to in-plane bending and 'simple bending' relate to out of plane bending?
Please explain:-)
Here you can download my file:https://dl.dropbox.com/u/61406729/DO%201_REV%2005.rtd
Thanks for helping
As you may see above it is not possible to define and calculate single layer for bending.
You can do it as you did but this warning will appear.
Keep it mind that in such case also both layers are calculated so to have reinforcement in one layer you add top and bottom reinf.
Yes, that,s why you can use single layer.
In reality yes - axial forces + inplane bending but robot does not have dof related to in-plane bending in shell FEs
OK, if I understand correctly, I can disregard the warning as long as I combine required bottom and top reinforcement in the single layer.
Thanks for all help.
I have the same problem as you did. I'm trying to reinforce a 100mm thick slab with a single central mesh. I followed the steps that you described above, but to no succes. If there's someone who can help me...
I've also attached my model.
I'm running Robot 2016.
Same problem here. I've done what you've showed, but there's no results.
Can someone help?
I've also attached the model, made in Robot 2016.
Thanks.
Hi @MariusR
For your cantilever slab you should set direction global Y rather than Z and simple bending instead of tension/compression. In such case Robot is not able to calculate only one layer of reinforcement in the middle of the slab (it is the limitation of the reinforcement calculation engine).
Hello Artur,
Thanks for your reply.
Disregard the fact that it's another geometry( i have multiple types of balconies to do).
I've done what you said, but then some errors appear :(.
Hi @MariusR
As I wrote Robot cannot calculate single layer reinforcement for bending. This is only available for walls under tension/compression (with no bending).
Edit your reinforcement database and create a neglible bar diameter of 0.01mm. Change cover deviation to 0 and cover of unused layer to 0.
